Working with non-standar pitches
capitan mission
Unread post by capitan mission » 13 Oct 2011, 20:38
Hi, I want to work outside the equal-tempered scale. As my first experiment I want to work with a few pitches, for example 100 hz, 200 hz, 300 hz, 400 hz and 500 hz.
Could you recommend me some approaches?
caco
Unread post by caco » 13 Oct 2011, 23:35
use the csound add-on, with csound you can generate any pitch you wish :)
capitan mission
Unread post by capitan mission » 13 Oct 2011, 23:49
caco wrote:use the csound add-on, with csound you can generate any pitch you wish :)
I need to learn how to use the csound add on, It seems a very powerful tool.
And what about the synthesis pack? I am searching add ons that work with any frequency.
CleverConQueso
Unread post by CleverConQueso » 14 Oct 2011, 06:45
There's a pitch shifter in the add on's you can modify to shift to non-standard tones. It uses the Vocoder objects, which you can also play with to make or modify pitches. Finally, there's a 'wave table' synth in the add on's that uses arrays to make wave forms. I've been playing around with these to create audio and they'll let you set your own pitches.
