two questions about sequencer
r.erorr
Unread post by r.erorr » 26 Sep 2011, 17:10
Hi, is there possible to get different tempo/speed for different seq-switches? I tried to connect some of counters to "step position" but it does not affect the values.
- is there possible to turn seq cursor run backwards?
Unread post by nay-seven » 26 Sep 2011, 17:46
here an idea:
CleverConQueso
Unread post by CleverConQueso » 26 Sep 2011, 18:55
On your first question, can you set the seq sync to 'loop' and calculate the duration as a fraction of the master tempo? Otherwise, I think you can put the seq in a sub-patch and set a local tempo. Or what happens when you connect a clock beat to 'next step'?
r.erorr
Unread post by r.erorr » 26 Sep 2011, 19:23
thanks for suggestions...
Users browsing this forum: No registered users and 49 guests
