about I/O on subpatches
Hi, I have several inputs and outputs of my subpacth, which is connected to other modules. But what if I decide to add some more inputs or out puts of my subpatch, the existing order has changed and all my connections to subpact are confused. I need to reconnect all strings again. Would be great if existing connections remains in order I connect them after new I/O added.
It happens specifically with poly sub patch.
we are working on this subject, but not easy to solve in the general case.
CleverConQueso
r.erorr-
I have some luck placing the new data-ins/outs at the top or bottom of the pre-existing ins/outs. There is some sorting by type which means that the new ones will be interspersed with the old ones but for the most part, this has reduced the amount of re-patching when I make changes. It's not foolproof but it has saved me some time.
CCQ
CCQ
