found on the net:
Tarekith's Guide To Optimizing WinXP for DAWs
Set Visual Effects To Minimum
Start > Settings > Control Panel > System > Advanced > Performance Settings > Visual Effects Tab > Adjust for best performance, re-enable ?Show Window Contents While Dragging?.
Set Processor Scheduling to ?Background Services?
Start > Settings > Control Panel > System > Advanced > Performance Settings > Advanced Tab > Background Services.
Startup and Recovery Options
Start > Settings > Control Panel> System > Advanced > Startup and Recovery Settings > Untick Automatically Restart.
Disable Error Reporting
Start > Settings > Control Panel> System > Advanced > Error Reporting > Disable Error Reporting.
Fix Swap File (Virtual Memory)
Start > Settings > Control Panel > System > Advanced > Performance Settings > Advanced > Virtual Memory Change > Custom Size. Set initial and maximum size to the same value.
Disable Fast User Switching
Start > Settings > Control Panel > User Accounts > Change the way users log on or off > Untick Use Fast User Switching
Switch Off Power Schemes
Start > Settings > Control Panel > Power Options > Always On > Turn off monitor and turn off hard discs to Never
Switch Off Hibernation
Start > Settings > Control Panel > Power Options > Hibernate > Untick Hibernation
Disable System Sounds
Start > Settings > Control Panel > Sounds and Audio Devices > Sounds Tab > Sound Scheme to None.
Do Not Map Through Soundcard
Start > Settings > Control Panel > Sounds and Audio Devices > Hardware Tab > (your soundcard) > Properties > Audio Devices > (your soundcard) > Properties > Check the "Do not map through this device" checkbox.
Disable System Restore
Start > Settings > Control Panel> System > System Restore Tab. Tick the "Turn off System Restore on all Drives"
Disable Automatic Updates
Start > Settings > Control Panel> System > Automatic Updates > Turn off automatic updating. I want to update my computer manually
Disable Remote Assistance
Start > Settings > Control Panel> System > Remote > Untick Allow remote assistance invitations to be sent from this computer
Disable Remote Desktop
Start > Settings > Control Panel > System > Remote > Untick "Allow users to connect remotely to this computer"
Disable Internet Synchronise Time
Start > Settings > Control Panel > Date and Time > Internet Time > Untick "Automatically synchronize with internet time server"
Disable Hide Inactive Icons
Start > Settings > Taskbar and Start Menu > Taskbar TAB > Uncheck "Hide Inactive Icons"
Disable Automatic Desktop Cleanup Wizard
Start > Settings > Control Panel > Display > Desktop > Customise Desktop > Untick "Run Desktop Cleanup Wizard every 60 days"
Remove Unused XP Components
C:Windows > Inf folder > Sysoc.inf. Replace the word "hide" with nothing, save file. Control Panel > "Add or Remove Programs? > "Add/Remove Windows Components". Components to be removed: Accesibility Options, Indexing Service, Update Root Certificates, Windows Automatic Updates, Windows Messenger, Games, Desktop Wallpaper, Explorer, Communications, MSN Explorer.
Disable Disk I/O Performance Logging
Start > Select Run > Type in ?diskperf ?n?, then hit Ok.
More User Options (XP Pro only)
Start > Select Run > Type in GPEDIT.MSC
Make Windows Explorer start in a different folder:
Right click on the Windows Explorer Icon, select Properties. Then copy the following into the ?Target? field:
%SystemRoot%explorer.exe /n, /e, c:
Clean your prefetch to improve performance.
Cpen C:/windows/prefetch, delete all files, reboot. Should only be done once a month.
Registry Tweaks
Speed Up Menus
Start > Run > Regedit > HKEY_CURRENT_USER > Control Panel > Desktop Folder. Set MenuShowDelay to 1
Disable Notification Area Balloon Tips
Start > Run > Regedit > HKEY_CURRENT_USER > Software > Microsoft > Windows > CurrentVersion > Explorer > Advanced. Create a new DWORD value called EnableBalloonTips and set to 0.
Disable CDROM Autoplay
Start > Run > Regedit > HKEY_LOCAL_MACHINE > System > CurrentControlSet > Services > Cdrom. Set autorun to 0.
Disable Recent Documents History
Start > Run > Regedit > HKEY_LOCAL_MACHINE > Software > Microsoft > Windows > CurrentVersion > Policies >
Explorer. Create a new DWORD 'NoRecentDocsHistory' set to '1'.
Disable Unused XP Sevices
Start > Control Panel > Administrative Tools > Services
NOTE: This Services guide was designed for a PC running ONLY music software. This does not apply to PC's online, on networks, or with printers and other peripherals attached. In my own experience I have found that messing with Services rarely has any measureable performance benefit. I never even bother changing these anymore as a result, but if you really have to, here's a list to get you started.
Use at your own risk please.
Alerter- Disabled
Application Layer Gateway Service- Manual
Application Management - Manual Automatic Updates- Manual
Background Intelligent Transfer Service- Disabled
ClipBook- Disabled
COM+ Event System- Manual
COM+ System Application- Manual
Computer Browser- Manual Cryptographic Services- Automatic
DHCP Client- Manual
Distributed Link Tracking Client- Manual Distributed Transaction Coordinator- Manual
DNS Client- Manual
Error Reporting Service- Disabled
Event Log- Automatic
Fast User Switching Compatibility- Manual
Fax Service- Manual
FTP Publishing Service- Manual
Help and Support- Disabled
Human Interface Device Access- Disabled
IIS Admin- Manual
IMAPI CD-Burning COM Service- Manual
Indexing Service- Disabled
Internet Connection Firewall- Manual Internet Connection Sharing- Manual IPSEC Services- Disabled
Logical Disk Manager- Manual
Logical Disk Manager Administrative Service- Manual
Message Queuing- Manual
Message Queuing Triggers- Manual
Messenger- Disabled
MS Software Shadow Copy Provider- Manual
Net Login- Disabled
NetMeeting Remote Desktop Sharing- Disabled
Network Connections- Manual
Network DDE- Disabled
Network DDE DSDM- Disabled
Network Location Awareness- NLA- Manual
NT LM Security Support Provider- Disabled
Performance Logs and Alerts- Disabled
Plug and Play- Automatic
Portable Media Serial Number- Manual
Print Spooler- Manual
Protected Storage- Manual
QoS RSVP- Disabled
Remote Access Auto Connection Manager- Manual
Remote Access Connection Manager- Manual
Remote Desktop Help Session Manager- Disabled
Remote Procedure Call- RPC- Automatic
Remote Procedure Call- RPC Locator- Manual
Remote Registry Service- Disabled
Removable Storage- Manual
Routing and Remote Access- Disabled
Secondary Logon- Disabled
Security Accounts Manager- Manual
Server- Manual
Shell Hardware Detection- Manual
Smart Card- Disabled
Smart Card Helper- Disabled
SSDP Discovery Service- Disabled
System Event Notification- Manual
System Restore Service- Disabled
Task Scheduler- Manual
TCP/IP NetBIOS Helper Service- Disabled Telephony- Manual
Telnet- Disabled
Terminal Services- Manual
Themes- Manual
Uninterruptible Power Supply- Disabled
Universal Plug and Play Device Host- Manual Upload Manager- Disabled
Volume Shadow Copy- Manual
WebClient- Disabled
Windows Audio- Automatic
Windows Image Acquisition- WIA- Disabled
Windows Installer- Manual
Windows Management Instrumentation- Automatic
Windows Management Instrumentation Driver Extension- Manual
Windows Time- Disabled
Wireless Zero Configuration- Disabled
WMI Performance Adapter- Disabled
Workstation- Automatic
How optimize XP for Usine
XP lite is very efficient.
I use it !
I use it !
I haven't tried it yet, but this comes recommended from some audio users as a free alternative to XP lite .. nLite (many prefer nLite over XP lite). XP lite removes Window components after the fact, nLite removes & creates a custom XP installation with all updates you like, before you install windows see:
nLite
nlite addon links
I'm building a DAW only computer soon, & am going to use Nlite to keep it rock solid. senso, thanks for the above tips.
nLite
nlite addon links
thanks
I'll try it
I'll try it
gREAT INFO, THANKS
Users browsing this forum: No registered users and 225 guests
