Designing a basic loop playback patch. pitch, pan, volume, etc. I realize that the volume and pan stuff is all contained in the little panel at the bottom of each track, but I want the controls large for easier use in a performance environment.
I would like to be able to make use of the aux sends provided for each track from within the patch I'm writing. Is there anyway to do this?
Best,
-Zach
controlling track parameters from inside patch
remember that in Usine all function can also be used in modules
here you can use the module/interface control/usine panel /mixer track output
and add fader/switches to fit your needs , here for the auxiliary :
