MIDI Matrix Note Off
CleverConQueso
Unread post by CleverConQueso » 12 Sep 2011, 19:22
When I turn off the MIDI matrix if there was a lingering note-on without a note off, then it doesn't turn off. I've been paring a 'from 1 to 0' with an all midi notes off. Am I using the matrix wrong or is this the best way to handle it? Should there be a note off associated with the MIDI matrix to deal with this?
- CCQ -
Unread post by senso » 17 Sep 2011, 17:02
This pb is more complex than it appears.
We are thinking about this point.
