Frea-Q Band Pass Filter Array
CleverConQueso
Unread post by CleverConQueso » 10 Sep 2011, 19:37
Folks-
I'm making a effect that is an array of band pass filters. I suppose it sounds a fair amount like the Resonator. The guts are band pass filters tuned to center frequencies from 50 to 7200 Hz. You can tune the left and right different so that the emphasis should travel from one side to the other.
A couple of questions -
I was hoping to make it sound like an EQ where you set individual bands to high emphasis and get a hollow sound. It's close, but it's not there. Any suggestions as to how to achieve this without including an actual bar EQ?
When the filter gains are set to rotate, I get a pop/click as the filter changes. I put a 'smooth' on the audio out but that only does part of the job and you pay for it in gain. Any suggestions there?
- CCQ -
Frea_Q
CleverConQueso
Unread post by CleverConQueso » 10 Sep 2011, 19:43
I set the input array to adjust the Q rather than the gain and it sounds nicer. Your thoughts?
Frea_q_q
- CCQ -
Unread post by nay-seven » 10 Sep 2011, 20:20
the second one is my preferred for the moment, some cool effect
