REC: save outputs as...
r.erorr
Unread post by r.erorr » 24 Aug 2011, 17:22
I would like to save all output channels as mono wav files or one predefined multichannel wave file.
Unread post by senso » 30 Aug 2011, 15:39
will be be probably added in futures versions. but I can't say when...
multiphone
Unread post by multiphone » 30 Aug 2011, 21:38
For once I can answer before Seven Nay! ;-) But after Senso :-(
To do this 2 Solutions:
1°) If your audio interface is an RME, the Digicheck utility is perfect for that. You can record everything that comes out of your sound card and save the file in mono or interlaced files
http://www.rme-audio.de/en_downloads.ph ... _digicheck
2°) With Bidule VST (http://www.plogue.com/?page_id=274) in Usine you can do the same things.
Best
HB
Lines / Points / Squares
http://www.hervebirolini.com/
r.erorr
Unread post by r.erorr » 04 Sep 2011, 13:42
of course there is also free ways
3) Jean-Marc Duchenne plugins multi rec 6, 16, 24 channels, but record output has a strange format.
http://acousmodules.free.fr/acousmodules6_en.htm
4) We can create it on Usine from mono or multichannel sampler modules, but anyway easy to do from record panel, if this is not hard to add that option
