Enable Audio Engine When Usine Loads
CleverConQueso
Unread post by CleverConQueso » 22 Aug 2011, 16:29
Does anyone know if it's possible to have the audio engine start automatically when Usine launches rather than requiring that the user press the space bar or click 'off'? I am looking for a patch to load automatically and start playing when the machine boots up without human intervention.
-CCQ-
gurulogic
Unread post by gurulogic » 22 Aug 2011, 17:47
This will do what you need. Put this in a master section patch.
Unread post by nay-seven » 22 Aug 2011, 21:36
or , if you don't want use the master section, you can add a always calculated module and use this patch in any patch
CleverConQueso
Unread post by CleverConQueso » 24 Aug 2011, 04:03
Thanks. team. Those work great. Funny how the second before I need something, there's a patch for it.
Unread post by woodslanding » 24 Aug 2011, 07:11
I've got my wkp to turn on and go to IB mode automatically, but I still always have to enable fullscreen mode myself. There doesn't look to be a dashbord input for that.....
Is there a way to do this by IML??
Unread post by nay-seven » 24 Aug 2011, 09:22
not sure for the iml, gone to check
but there's the midi learn option which works fine, here i've use a midi learn of CC 23 on the full screen button:
Unread post by woodslanding » 24 Aug 2011, 19:25
Ahhh--that'll do!
