invisible/dummy button trick ?
protofuse
Unread post by protofuse » 15 Aug 2011, 19:20
hello,
I'd like to fold/unfold, I mean, hide/show, some containers containing a bunch of UI elements.
In order to make that, I'd like to use a button.
but when a button is hidden, it is also disable.
would there be a trick/tip for me here ??
best,
Unread post by nay-seven » 15 Aug 2011, 19:53
not sure to understand what you mean here, your button stay visible, so you put it outside the container..?
protofuse
Unread post by protofuse » 15 Aug 2011, 20:06
yep of course
I need to have it invisible, but active (if I take the same concept in Max5)
And I tested, if my button is invisible, it isn't pushable (which could really make sense but could be not enough too)
Unread post by nay-seven » 15 Aug 2011, 20:41
so i suppose you can have a button of the same color than the background...?
protofuse
Unread post by protofuse » 15 Aug 2011, 20:47
yes I can if I don't have a picture in the background or anything with a color gradient
it is the same thing with the text & transparent background
but yes, the workaround works in the case of solid color etc.
I probably have to find another trick to use it in another case.
