parent container/master container??
ErotiCore SteNch
Container are like panels and are useful if you want to group controls inside a single entity. here a little patch to illustrate :
download
but a container can't be shared by multiple tracks, it's just a kind of folder in a patch
download
ErotiCore SteNch
thanks
but whats the different between maincontainer or parent container and a ordinary container?
it could be cool IF a container could be shared by multiple tracks though i guess that would be insanely diffucult to manage:)
it's the same hierarchy target than for control panel. in my example, choose the fader named fader in sub container and change his option
where= container
for
where = parent container
i know this concept is not always easy at first
where= container
for
ErotiCore SteNch
thanks for your excample yeah it is confusing:)
can be confusing at first but really useful when you have for example some group of switches to move ...
will try to built a wiki page about hierarchy in Usine.
ErotiCore SteNch
thanks,i think it all will make much more sense when i get a bit more used to usine.and i already have gotten alot of help on this forum for that i thank you:)
how to "attach" some elements to a particular container ?
the where property doesn't seem to be enough (I mean, I missed something else for sure)
julien
julienbayle.net
designthmedia.com
soundcloud.com/protofuse
_ _ _ _ _ _ _ _ _ _ _ _ _
Ableton Certified Trainer
julienbayle.net
designthmedia.com
I just missed something: my children element was at the bottom of a non-autoresizable container (so I didn't see it anymore)
btw, it works fine!
btw, it works fine!
julien
julienbayle.net
designthmedia.com
julienbayle.net
designthmedia.com
Users browsing this forum: No registered users and 60 guests
