VstTimeInfo to Host from Easine exported VST/i ?
Hi guys,
since i often deal with live impro looping it's essential for me to communicate BPM and ppq's and all the relevant Tempo related infos to the host of my choice. This way i can record on the fly something in my patch e communicate to the host the right tempo.
Can it be done with exported VST/i ?
many thanks for the info.
alfonso
alfonso
Actually impossible because not implemented in most of hosts and not included in the VST protocol.
In other words a VST can't the host tempo in the general case, absolutely not a pb with Usine.
Technically the 'audioMasterSetTime' function is deprecated in VST2.4 specification...
A suggestion for Steinberg?
hi senso,
anyway in Synthedit there is a module made by Chris Kerry ( actually under my suggestion several years ago ), that does exactly this.
Bidule i.e. can receive as a host Tempo infos.
I'll make some pressure on Ableton Live
In the case of ableton i think that is possible to put a VST in a Max4Live "shell" and then receive the tempo info from the VST and translate it for ableton using the verious Max4Live<->Ableton Live intercommunication techniques.
a.
a.
As I said most of host don't receive TimeInfo. As I know, only Bidule can, but easy because it's not a sequencer...Bidule i.e. can receive as a host Tempo infos.
yes but it's not a VST, it's like in Usine: you can change the tempo within a patch!In the case of ableton i think that is possible to put a VST in a Max4Live "shell" and then receive the tempo info from the VST and translate it for ableton using the verious Max4Live<->Ableton Live intercommunication techniques.
Search 'audioMasterSetTime' on the net you'll read very instructive literature.
yes...i'll give you an example VST that actually works i.e. in Bidule
as soon as i came back from gigging around.
for the Max4Live thing in the mean-time one can do the calculations inside the VST and let it come out as a 0-1 range audio signals and send it to Ableton via Max4Live...not super precise...but at least can work...i guess
thanks
a.
thanks
a.
hehe.. true...is a modular enviroment.
Usine can as a host with its own patches...and Ableton Live can with M4Live Patches...
i was planning of using Usine Exported VST and M4Live Patches inside Ableton...
Have you thought about using Live as a ReWire slave? Using the ReWire VST from energyXT you can set up Usine to be a ReWire master.
I don't use Live, but I use the ReWire VST to slave Reason to Usine and it works fine.
Users browsing this forum: No registered users and 297 guests
