top panel + splashscreen little issues for exported VST...
protofuse
Unread post by protofuse » 09 Aug 2011, 09:19
Hello mates,
you DID a great job.
VST exported work very fine.
It doesn't suck too much CPU
It drives 1000Hz ACCURATE (!) ticks maxi which is VERY big (basically 10x more than Synthmaker, which offers 100Hz and UNaccurate ticks!) which offers more sequencer making capabilities.
And many more stuff I probably didn't discover yet.
I tested it in several DAW and it is very robust and solid.
ABSOLUTELY NO crash, nothing bad!
I tried to use many VST exported ... no problem etc.
I'd just require something which could be in a RC 03 or official release before to begin to wait for maybe a dev version:
- ability to disable or enable the top panel export in the VST.
- ability to disable the splashscreen when you load the VST into an host
I imagine it could be hard to provide those 2 options right now, but this is the last thing that limit me/designthemedia.com to completely dive.
please, let offer that to us : )
I already asked that to you, which it could seem to be a bit harrassing (:p) but I'd like to invest me and us inside the tool in order to release something quite soon, so, I officially ask that here :)
all the best,
Unread post by senso » 09 Aug 2011, 16:44
thanks for comments.
It's more a suggestion?
As we tell you before, we are working for a developer version of Usine but we need time and more feedbacks.
The RC04 will have a lighter dashboard.
protofuse
Unread post by protofuse » 09 Aug 2011, 16:45
Great news : )
I'm staying tune (and plugged physically in Usine Patchers !!)
protofuse
Unread post by protofuse » 09 Aug 2011, 17:21
Indeed.
I like this change.
It is great, imho.
thanks!
jean-marc duchenne
Unread post by jean-marc duchenne » 09 Aug 2011, 18:55
Yes, I find it better like this.
Perhaps would it be possible to align the buttons and other objects so they have all the same (thin) height, like the menu button ?
Users browsing this forum: Bing [Bot] and 588 guests
