Compilation problems here with VSE 2010 :-(
protofuse
Unread post by protofuse » 07 Aug 2011, 17:09
Trying to compile Granulator example project, I had that:
Code: Select all
1>------ Build started: Project: Granulator, Configuration: Release Win32 ------
1>  Granulator.vcxproj -> C:DATADEVUsine_CPP_SDKbinGranulator.usr
1>  Est-ce que C:Program FilesUsine Pro StandAlone 5.50ModulesAudio désigne un nom de fichier
1>  ou un nom de répertoire de la destination
1>  (F = fichier, R = répertoire) ? ?   l)              ½  9  C  >    >  ╬    C   l            Est-ce que C:Program FilesUsine Pro StandAlone 5.50ModulesAudio désigne un nom de fichier
1>C:Program Files (x86)MSBuildMicrosoft.Cppv4.0Microsoft.CppCommon.targets(113,5): error MSB3073: The command "xcopy /e /i /y "C:DATADEVUsine_CPP_SDKbinGranulator.usr" "C:Program FilesUsine Pro StandAlone 5.50ModulesAudio"
1>C:Program Files (x86)MSBuildMicrosoft.Cppv4.0Microsoft.CppCommon.targets(113,5): error MSB3073: :VCEnd" exited with code 2.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
For SURE, I don't have anything placed in "C:Program FilesUsine Pro StandAlone 5.50ModulesAudio"
Where did I miss something ? It is the "basic" PATH problems :P
anyone this sunday afternoon ?!
best,
martignasse
Unread post by martignasse » 07 Aug 2011, 18:55
hi protofuse,
is a post build error, it's set in the project properties->build events-> post build event
the line
Code: Select all
xcopy /e /i /y "$(OutDir)$(ProjectName).usr" "C:Program FilesUsine Pro StandAlone 5.50ModulesAudio"
copy the fresh module to your usine install
you surely have to delete it or update the dest path to your install
protofuse
Unread post by protofuse » 08 Aug 2011, 14:22
I did
It works!
thanks a lot martignasse
Users browsing this forum: No registered users and 37 guests
