Please, offer us a Load SubPatch
protofuse
Unread post by protofuse » 06 Aug 2011, 12:24
This suggestion comes from this post
Actually, Load Patch load a patch where you want by replacing totally the previous one (which is normal, useful & efficient!)
I'd like to design reuseable patch (possible already...) and I want to keep this object independant, in specific folders.
Example, I need to code a double LFO.
I patch this one with the intent to use it later.
I patch another synth, using double LFO.
I patch another fx using double LFO.
and ... I decide to improve that OLLLLD double LFO. I improve it.
When I load anything using double LFO, the new one has to be loaded.
This would be amazing.
Best,
Unread post by senso » 07 Aug 2011, 09:01
The actual behavior is implemented to ensure the maximum security and backward compatibility.
Usine evolving so quickly !
But I can add a reload sub patch...
protofuse
Unread post by protofuse » 07 Aug 2011, 10:21
Sensomusic is magic!
It would be nice and useful.
Let us know :P
