in the piano roll the start point and the end point are allways quantized to 8th notes.
now i am playing music with beatmorphing, but i can not smoothly morph from one lenght to another with quantisation. could you add a button for a free range start and end point?
is there a workaround without the piano roll?
piano roll start pos /end pos quantisation
Have you try to use the synchro = play button..?
you're right.
I'll take a look.
I'll take a look.
this is a workaround to freely change the end position of a piano roll loop. the start ist still quantized.
http://sensomusic.com/downloadaddon.php ... ition_.pat
Users browsing this forum: No registered users and 3 guests
