share a workspaces & patches + specific design easily ...?
protofuse
Unread post by protofuse » 02 Aug 2011, 19:59
we are a team
we'd need to share our patches & our worspaces
how could we do that, considering:
- we use specific design preset for UI elements,
- we use compiled user module (we already made some test... guys, again, you rock!)
should we share the workspace + the patch + ALL specific stuff ?
how could we do this easily ?
best,
Unread post by nay-seven » 02 Aug 2011, 20:06
have you test the menu file/export workspace function..?
[ ctrl+E ]
protofuse
Unread post by protofuse » 02 Aug 2011, 20:36
yep
but it exports the workspace & the patch.
if I use specific module preset & specific bitmap for knobs (for instance), how would it work ?
Unread post by nay-seven » 02 Aug 2011, 20:42
yes, this can be improved .
waiting for this you can put your users module in your personal library and share it
about the design, you can create a dir in files/skin/my skin and share it too ..?
protofuse
Unread post by protofuse » 02 Aug 2011, 20:48
it was just to understand how it works.
got it!!
thanks.
I'll do that and it is very ok
Users browsing this forum: No registered users and 390 guests
