I understood the workspace & patch concepts.
I checked the IB & GRID mode too.
I have a question.
Where should I put my UI elements in order to make them exposed & useable when I want to use my workspace as a VST ?
I guess this question will be the same when I'll want to export as VST.
Another way to ask this same question: what is the higher level of UI ?
any infos wuld be appreciate.
best,
What is the entity where I have to put my UI elements for VST use ?
julien
julienbayle.net
designthmedia.com
soundcloud.com/protofuse
_ _ _ _ _ _ _ _ _ _ _ _ _
Ableton Certified Trainer
julienbayle.net
designthmedia.com
Really simple :
Open Easine , drag and drop for example the patch from Browser/Usine/audioFX / scratcher
Resize the main Easine window to select the final window size for your VST
Export as VST
that's all
note :We suggest you to use Easine for all your VST creations. The VST generated with Easine is lighter and fully integrated in hosts.
Export as VST
that's all
thanks nay-seven!
but, can I create ALL patches, code, etc in easine ?
I'll check that right now
julien
julienbayle.net
designthmedia.com
julienbayle.net
designthmedia.com
And specially if you need to create a multi-channel project , Easine can have up to 32 in/out !
got it!
I can feel the 5.7 coming from my horizon...
cannot wait
cannot wait
julien
julienbayle.net
designthmedia.com
julienbayle.net
designthmedia.com
Users browsing this forum: No registered users and 553 guests
