About GUI elements design
protofuse
Unread post by protofuse » 30 Jul 2011, 19:39
Dear new friends,
may I ask a question which could sound newbie?
ok. I guess I can.
Can we create from scratch UI elements ?
I mean, buttons, sliders, panels etc everything ?
cheers,
Unread post by nay-seven » 30 Jul 2011, 21:21
Hello protofuse, glad to see you here
i will let the SDK specialist answer for the code part, on the patch level you can use of course the edit layouts possibilities and also import design created with Knobman for example.
protofuse
Unread post by protofuse » 30 Jul 2011, 21:27
Okay :)
I guess, we could also use "pure" vector or bitmap graphics too, right?
Unread post by nay-seven » 30 Jul 2011, 21:44
on patch level, jpg and bitmap yes
protofuse
Unread post by protofuse » 30 Jul 2011, 21:51
got it.
(thanks :)
free version unavailable
I wait for a bit
I'd like to begin to play but I'd buy the maxi/pro version in order to really test deeper.
