inverse fader?
Floego
Unread post by Floego » 21 Jul 2011, 00:48
another little suggestion::)
a fader, either vertical or horizontal but with the option to increase the value from the top to the botton and from right to left, that is, the inverse of the way it actually is.
I'm aware that is relatively easy to crossfade the values but that way is imposible to show the correct value inside the fader itself.
Unread post by nay-seven » 21 Jul 2011, 08:41
waiting for this, a little tips ( disable show value in the layout ) :
Floego
Unread post by Floego » 21 Jul 2011, 13:23
good tip :)
