OSC Send and SendText Maximum Port Number
CleverConQueso
Unread post by CleverConQueso » 14 Jul 2011, 23:03
Does anyone know if there's a way to raise the port value maximum to a value higher than 9999? I've got a OSC wrapper that's using 12345 as its listen port. Does anyone know a trick to redirect?
- CCQ -
Unread post by nay-seven » 14 Jul 2011, 23:16
no tricks right now, but maybe Senso can increase the possible number for next version..?
CleverConQueso
Unread post by CleverConQueso » 15 Jul 2011, 00:24
<Oops. Nevermind. Found the 'string'./>
Thanks, Nay-Seven. While I'm asking, do you know if there's any plans to have OSC Receive accept string data?
Unread post by senso » 15 Jul 2011, 09:51
no problem to increase the port number!
next release.
CleverConQueso
Unread post by CleverConQueso » 08 Aug 2011, 17:53
Thanks Senso. Works as promised.
Users browsing this forum: No registered users and 28 guests
