FL Studio control from Usine?
fnatic99
Unread post by fnatic99 » 08 Jul 2011, 19:51
I want to control FL Studio (instruments, effects...) from Usine.exe.
So i made a patch with a bunch of knobs and midi out.
There is a midi signal in FL Studio but im getting all kind of weird midi data.
I have tried with midi filter but with no luck.
Basically i just want to map knobs in Usine to FL Studio knobs and move them from Usine.
Can some one help me?
Cheers!
Unread post by nay-seven » 08 Jul 2011, 20:22
don't know how you patch this, but you don't need midi out modules
here a simple example :
a fader
right click and find in remote panel
enter : canal number, 176 as midi message, number of the controller and set remote ON
now in you global midi setup , set midi out /fast mode and remote ( trace if you want to check )
that's all..
fnatic99
Unread post by fnatic99 » 08 Jul 2011, 21:27
wow its so easy!
it worked!
i was just complicating stuff :)
thanks a lot for help & quick response!
cheers!
Users browsing this forum: Bing [Bot] and 106 guests
