Muting a midi note
noise2sine
Unread post by noise2sine » 24 Jun 2011, 09:35
i was wondering how i can make this :
Having a piano roll with a midi file corresponding to a drum pattern : C1 for the kick, D1 for the snare and E1 for the hihat .
How can i decide to mute thanks to a button a specific note ?
I'm sure the midi filter will do the job but i didn't find a way to make it work properly :(
Thanks in advance
franck
Unread post by franck » 24 Jun 2011, 09:58
I think there is a drum edit to Olivier " to do lis".
franck et ses amis
Unread post by nay-seven » 24 Jun 2011, 10:32
Something like this...?
filter = note on
noise2sine
Unread post by noise2sine » 24 Jun 2011, 10:41
humm!!!
Thanks Nay, i'm going to try this right now ! and let u know !
Unread post by nay-seven » 24 Jun 2011, 11:23
mm, sorry , bad screenshot , here the good one :
noise2sine
Unread post by noise2sine » 24 Jun 2011, 12:32
Which are the diference between the two ??
Unread post by nay-seven » 24 Jun 2011, 13:11
first one don't work
and you can of course delete the filter module in the second one:
sorry, last night was short..;-)
noise2sine
Unread post by noise2sine » 18 Jul 2011, 13:19
Hello Nay,
I have tested your patch idea, it works fine but i have noticed some strange things :
First, as i'm using a piano Roll i have to use the MIDI FILTER no ?
Secondly : In order to test the patch i'm using two piano roll. the first one plays a simple midifile and the second is plugged to the STOP out inlet in order to record what is going on. And what is recorded didn't correspond to initial midi file played by the firsdt piano roll !
The first bar is more or less recorded correctly, but the second bar and so on isn't all !
What's going on ??
noise2sine
Unread post by noise2sine » 18 Jul 2011, 14:19
Hello Nay,
It's working perfectly !
Thank u very much
Users browsing this forum: No registered users and 33 guests
