Spring cleaning in the add-ons database
Unread post by nay-seven » 20 May 2011, 14:58
hello ,
I've done a spring cleaning in the add-ons database and move some of them in the new archives section
this way no addon will be lost.
Here are some of the reasons to move them :
buggy ones
use old script
multiple versions ( I've keep the last one )
obsolete
too big or bad interface /layouts
some need just little updates ( example when used with the old matrix module )
If you have questions about one of your addons, no problem of course, just ask
you can also try to update your add-on and create a new version ( ask also here if you need precisions )
Users browsing this forum: No registered users and 262 guests
