I have a problem using guitar amp VST
I'm using Reaper DAW. But I got Harsh sound especially in high end, I've used Protools, and Cubase too, I've tried many guitar amp VST. And many computers, and the result is always the same.
I have been checking a long time and I couldn’t find the problem. I think is because the internal process of my PC. I don’t understand why I still can’t get a good sound.
My PC Specifications
Intel Core 2Quad CPU
Q8200 @ 2.33GHz
2.33GHz, 3,24GB RAM
I have read about VST getTimeInfo() performance http://forum.cockos.com/project.php?issueid=2110, but I don't understand too much,
I really hope somebody can help me.
Thank you in advance
HARS SOUND VST guitar amp
hello & welcome Eliza
have you tried your vst in Usine too..?
same results..?
you can use some test program like this one to test your PC :
http://www.thesycon.de/deu/latency_check.shtml
same results..?
you dont tell about your audio interface/sound card. is it the on board sound chip? and speakers matter alot, too...
if u used the same speakers with the different pc s and software then it might be a speaker problem. it can be a problem with guitar amp. too, maybe it has a bug. i dont know the software...
thinkpad t61, xp 32bit, 2gig ram, rme multiface // acer timelinex 3820t, win7 64bit, 4gig ram, NI komplete audio 6 // reaktor, battery, nuendo // roland hpd15
Users browsing this forum: No registered users and 319 guests
