math problem
joffo78
Unread post by joffo78 » 13 Apr 2011, 18:20
Hi
Nobody on the french forum to help to resolve my problem ?
I'll try to explain it here.
I'd like to convert pitch data in time data.
i can modify the pitch with positive negative or 0 values (0 mean no pitch so 100% of the duration of my sample)
I'd like to deduce the operator which permit me to calculate the duration of my sample when i modify the speed.
thank you.
Jof
Unread post by nay-seven » 13 Apr 2011, 21:47
sorry, was dreaming during maths lessons..
any maths guru for joffo..?
Unread post by 23fx23 » 13 Apr 2011, 22:43
mmm speed double and length reduce of half when pitched an octave (+12),
so if not wrong should be len= original len / (pitch/6) maybe.
Unread post by bsork » 13 Apr 2011, 22:44
I was sure I had brought up this issue once, so I did a search and found this thread from 2006. You'll find the formula there.
joffo78
Unread post by joffo78 » 14 Apr 2011, 07:16
ok thank you
this formul : original_length / 2^(pitch/12) = shifted_length
seems interest me but i don't know what the symbol ^ means...
and how can i apply this formule in usine ?
caco
Unread post by caco » 14 Apr 2011, 08:43
^=power.
It's in the maths section of the browser as A ^ B (power)
joffo78
Unread post by joffo78 » 14 Apr 2011, 11:06
So i tried to traduct this : 300 / 2^(7/12) = 200.225978126 in usine language without success :(
may i did some mistake ?
Unread post by nay-seven » 14 Apr 2011, 11:23
here it is : ( when there's parenthesis...)
Unread post by senso » 14 Apr 2011, 11:29
@bsork: you're the Usine's encyclopedia!
joffo78
Unread post by joffo78 » 14 Apr 2011, 12:01
thank you you're masters !
joffo78
Unread post by joffo78 » 15 Apr 2011, 09:24
So Nay you're not so bad in math.No more than me !
