Audio to MIDi patch help?
RunBeerRun
Unread post by RunBeerRun » 08 Apr 2011, 01:00
I can't get the audio to midi patch to output and MIDI. In previous versions of Usine, after loading the patch I had to click on the schematic and find a midi output module and specify a channel, I'm not seeing that in the latest version.
Thanks!
Edit-Solved by adjusting threshold, there was no need to specify MIDI functionality
RunBeerRun
Unread post by RunBeerRun » 08 Apr 2011, 01:44
I have input correctly selected, producing note-on events but they turn into OFF events. I have MIDI Trace in and out selected, and now can see in the upper right hand side what it's doing, but it can't find my M-Audio Fast Track Pro midi channel or MIDIYOKE.
Although neither should be needed for audio to midi, I just want midi to output Usine into a vsti.
Unread post by nay-seven » 08 Apr 2011, 07:41
if you want change the midi channel you can do it in the midi transform module
try to reduce threshold, will work
you mean you don't see your device in the global setup/midi out..?
RunBeerRun
Unread post by RunBeerRun » 08 Apr 2011, 15:34
Thanks, it was the threshold. Works now, and I can play with it further.
There's still no sign of my MIDI interface in setup.
Unread post by nay-seven » 08 Apr 2011, 15:57
and do you see it in the audio part..?
I've the M-Audio Fast Track Ultra for my part and no particular problem with . Can you see it in an other host..?
RunBeerRun
Unread post by RunBeerRun » 08 Apr 2011, 16:16
I can't see any M-Audio Fast Track Pro or Midiyoke in Usine, but they show up in any other host.
In the audio to midi patch, inside the schematic, the midi out module near the end still says off, but the trace out stuff has it as on, which is what's happening.
Unread post by nay-seven » 08 Apr 2011, 16:38
and you see others interface..? asio4 all..?
RunBeerRun
Unread post by RunBeerRun » 08 Apr 2011, 16:59
Within Usine vst? I don't see any asio setup anywhere, but then in Reaper I see M-Audio, also ASIO4ALL.
Unread post by nay-seven » 08 Apr 2011, 17:28
ha , ok you was talking about the vst version...
so it's normal you don't see any interface, the midi in / outs are defined by reaper here..
if you want use the midi out of Usine VST, add a new receive in a second track for example in the send/receive options of the track
RunBeerRun
Unread post by RunBeerRun » 08 Apr 2011, 17:35
Yes, I'm using the free version of the vst. I have a vsti synth loaded after it in Reaper and it works.
Users browsing this forum: No registered users and 25 guests
