HID divices
r.erorr
Unread post by r.erorr » 27 Mar 2011, 07:41
Can I use my PC keyboard or other HID devices instead of MIDI? Key learn is good option, but it doesn't work inside VSTi. Is here somehow possible to play VSTi with keyboard?
- Thanx in advance -
Unread post by nay-seven » 27 Mar 2011, 10:56
hello & welcome r.erorr,
If you want to play midi notes, here a patch to use your keyboard :
If you want use your keyboard to control a parameter , here an idea , note i use 0.1 as increment value:
Unread post by nay-seven » 27 Mar 2011, 11:18
and depending of your HID device , you can use an array to use his information, here a saitek joystick :
r.erorr
Unread post by r.erorr » 30 Mar 2011, 02:59
Really thanx for useful info.
r.erorr
Unread post by r.erorr » 30 Mar 2011, 04:54
nay-seven wrote:hello & welcome r.erorr,
[img align=c]http://www.sensomusic.com/forums/upload ... i%20in.jpg[/url]
[img align=c]http://www.sensomusic.com/forums/upload ... 20knob.jpg[/url]
I also find interesting thing with respect to parameter control on keyboard. This is little strange to switch on the increment and decrement buttons and reverse the on/off values[for both buttons and switches], but in result is not necessary to push the buttons many times for increase or decrease - just hold down the key and gain increase or decrease in accordance with gain knob increment value.
[img align=c]http://funkyimg.com/viewer.php?img=/2/744/066/patch.jpg[/url]
Users browsing this forum: No registered users and 246 guests
