Hi everybody !
I have a problem with a controleur I'm using since a few days only, the AKAI mpk mini. Te thing is that when I turn knobs fast, Usine stops for like a second, and then restart normaly. It doesn't happen with the nanokontrol or the joystick. I've also tried to use differents usb port, but it doesn't seem to change anything.
As anybody an idea ?
Thanks a lot !
Controleur problem
tanabarbier
have you a cpu spike in the same time..?
and if you set the trace midi in , what kind of message is sent..?
tanabarbier
You're right, it seems to be due to CPU overload, but the funny thing is that it doesn't happen with other controlers. I setted the latency of my external sound card a bit higher and it's ok.
Thanks !!
Thanks !!
Users browsing this forum: No registered users and 393 guests
