send tempo to master sync: strange issue
What do you use to send this value...?
have you tried to insert a math/ trunc module before the tempo inlet..?
Hello Héliouk,
Does your master tempo receive 130,03 or does it receive 130 and become 130,03 ?
Check your "perfect synchro" option in set up ... try to desactivate it and your master synchro should be 130 if it received 130 ...
see you
see you
for info : to avoid this behavior, disable the 'perfect synchro' option in the Setup/Asio panel.
thanks a lot guys!
i was sending integer value,but now (with perfect syncro off!) ,it' ok.
amazing no?
amazing no?
As far as I understood, the "Perfect Synchro" is related to the buffer size of your sound card, so 130,03 bpm was a multiple of your buffer size and 130 was not a multiple, so tempo goes to the nearest bpm multiple ...
hope I'm clear ...
see you
hope I'm clear ...
see you
yes it's clear...i didn't know about that
thanks mister mondo.
see you
see you
Users browsing this forum: No registered users and 192 guests
