Polyphonic subpatches and remote controls
gthibert
Unread post by gthibert » 15 Mar 2011, 22:20
First of all, I use polyphonic subpatches a lot, and it's realy powerful. And even more with a little trick i've found : adding the current voice number as a suffix to buses name (with concat string connected to name inlet of busses), wich allow ''voices'' to communicate between them or to send data independently to each voice.
But there's a thing that is a bit annoying. When the polyphony is applyed, Usine copy the remote control assignations (midi) of the first patch in polyphony to others. So each time I make a little change in the patch and apply polyphony, I must reasign all my MIDI controls, and I use a lot of them. So it takes me a lot of time. And it's realy frustating when I realize that I must change something in the patch, and reasign everything again! ;-)
It would be realy convenient if Usine could rember all those assignations.
Guillaume Thibert
www.cemproduction.com
Unread post by senso » 15 Mar 2011, 22:40
yes you're totally right,
This will be implemented in the next release (5.50.53 and above) :)
gthibert
Unread post by gthibert » 16 Mar 2011, 00:01
Merci Senso!
Guillaume Thibert
Unread post by 23fx23 » 19 Mar 2011, 10:36
cool. by the way i just tested more deeply polyphonic concept wich is pure genius made!
