Important update Usine 5.50.521 poly
Announcements
Unread post by senso » 15 Mar 2011, 20:54
[large]Usine / Easine 5.50.521[/large]
Must be downloaded to replace the 5.50.52
This version solves important bugs and hard crashes on the MapperCurve module.
fixed bugs
- [module] hard crashes with the MapperCurve
- [library] the DJ Gate doesn't work properly.
Improvements
- [library] new version of DJ Gate
- [library] new version of DJ Peak Filter
[large]Usine / Easine 5.50.52[/large]
This version contains several improvements and fixes some important bug.
Also contains a new library called DJ set which provides up to 7 new DJ oriented FX.
You should download this update.
Please read the notes bellow.
Improvements
- [module] new Formant Filter module
- [module] new multichannel crossFader module
- [module] optimization of the delay module (2x faster)
- [module] new ramp module. The old version (5.25) of the ramp is reintroduced for compatibility.
- [module] sampler : new "long filename" outlet
- [library] new DJ FX pack (contains 7 special DJ FX)
- [library] new version of Bit Crusher
- [library] new version of Reverse
fixed bugs
- [module] the keyboard module doesn't work properly
- [module] bad initialization of the 1-X module
- [module] bad initialization of the delta module
- [conductor/preset] some time you're obliged to press the recall button twice
notes
- on this version some conductor/preset lines on array's and steps modules aren't
recalled properly and you're are obliged to press recall two times.
This bug will be solved if you re-save your presets/conductor lines.
waolelaid
Unread post by waolelaid » 16 Mar 2011, 04:57
hello all go well thanx ;)
Friedrich Nietzsche
Users browsing this forum: No registered users and 219 guests
