128_presets_with_scroll
Unread post by nay-seven » 12 Mar 2011, 18:14
Simple patch to store presets, provide a scroll function to use up to 128 presets
Based on the 128 presets patch from 23fx23.
Just put it as a sub-patch in any patch you want to manage and use it as a classic Preset Manager.
Unread post by 23fx23 » 12 Mar 2011, 18:28
cool!
Unread post by grego mondo » 14 Mar 2011, 02:07
I love it !!
joffo78
Unread post by joffo78 » 14 Mar 2011, 13:29
very nice !
i'll try it to manage my light scenes !
jeanrene
Unread post by jeanrene » 11 Aug 2011, 15:30
nice work!!!
PatcherKit at work.
ErotiCore SteNch
Unread post by ErotiCore SteNch » 11 Aug 2011, 17:13
could this also be used to store a full say "live set"?
say you have 8 samplers(microwave)1 sampler for each instrument group(drums,bass etc)that loads audio files from a list
could this be used to store the samplers loaded with all the samples for track ,track2,track 3 etc
so say when you play live and your finished playing track one,you could load the stored stuff for track 2??
or is it the conductor i need to look into?
anyways good job nay-seven:)
Unread post by nay-seven » 11 Aug 2011, 18:18
thanks guys, but the engine was by 23fx
@ErotiCore SteNch : yes, conductor is needed to manage several tracks cause the target of a preset manager can be only a patch ( and parent and top parent but that's all )
