I offer my services as a spanish traslator : )
All about the Usine Manuals & Wiki
capitan mission
Unread post by capitan mission » 04 Mar 2011, 19:47
Hello, I saw that Floego is making translations to spanish, I want to help too.
Sugerences are welcome
Unread post by nay-seven » 04 Mar 2011, 19:54
thanks a lot captain !
be sure we 'll give you some work soon...:D
have you yet work with wiki...?
que te vaya bien...!
capitan mission
Unread post by capitan mission » 04 Mar 2011, 20:17
I have little experience with wiki, but for sure I will learn : )
es un placer ayudar en este gran proyecto
Floego
Unread post by Floego » 05 Mar 2011, 02:48
Bienvenido capitan mission!
good to know you have willingness to help on spanish translations. :)
capitan mission
Unread post by capitan mission » 05 Mar 2011, 05:16
tengo toda la voluntad!
(secret spanish code hehe)
Unread post by nay-seven » 05 Mar 2011, 09:48
ok,
one of the thing you check is the last changes page :
http://www.sensomusic.com/wiki/doku.php ... astchanges
you don't have to translate this page but this give you all the last modifications done on the manual, generally with each update.
Then , the second big part could be the patching tutorial ?
http://www.sensomusic.com/wiki/doku.php ... w_to_patch
y si lo quiero , puedes ver con floego si tu necesita ayuda con el wiki..?
y como dice mi abuela :
el foro , unido, jamas sera vencido !:D
capitan mission
Unread post by capitan mission » 05 Mar 2011, 17:50
"If permissions allow, you may create it by using the Create this page button."
I dont see the "create this page" button, I dont have permissions or Im blind? : )
Unread post by nay-seven » 05 Mar 2011, 18:07
ok, so here an example :
let's use this page :
http://www.sensomusic.com/wiki/doku.php ... opendialog
this page exist only in English
the first thing to do is to copy the contents, so click on the Edit button
ctrl+A , ctrl+C to copy all the page
now click on the cancel of this page.
now, you're back on the wiki page, click on the little ES button
wiki tell you : Este tema no existe todavía
use the : crear este pagina button
ctrl+V to paste all the content of the page
translate what is needed...and save your page
Unread post by nay-seven » 05 Mar 2011, 18:12
but , I'm stupid...you're only member...you can't edit the wiki...
i' m gone to see if there's a solution...
capitan mission
Unread post by capitan mission » 05 Mar 2011, 18:39
ouch. I hope there's a solution.
I have a website about trekking, so I have some experience working with web-pages, writing... I found it strange not to be able to edit a wiki!
Unread post by nay-seven » 06 Mar 2011, 18:27
Ok, so I've update your account as Premium member , this way you'll can edit the wiki...
capitan mission
Unread post by capitan mission » 06 Mar 2011, 19:32
Sorry Nay, I cant edit in this way either, the only button that I see is the "print" one :(
Unread post by nay-seven » 06 Mar 2011, 22:56
ok, sorry was pretty sure premium member can edit the wiki..
problem : i can't edit those rights so the only solution I've is to upgrade again your account and this time as gold member, hope you'll appreciate...;-)
capitan mission
Unread post by capitan mission » 06 Mar 2011, 23:18
Nay, I really appreciate this! :)
I will work a lot!!!
I started to translate the updates. And tomorrow I will start to translate the patching tutorial .
Floego
Unread post by Floego » 07 Mar 2011, 04:05
captain mission, if you have any question related to the spanish translations, just let me know!:)
capitan mission
Unread post by capitan mission » 07 Mar 2011, 05:12
Ok! Muchas gracias Floego. Thanks.
Users browsing this forum: No registered users and 145 guests
