track virtual inputs
soundmind
Unread post by soundmind » 03 Mar 2011, 17:01
a track input idea,
when you select a track as an input to another track with the "virtual input" combobox at the top of each track and the incoming track contains more than one output, only the first output is received in the receiving track. Is there a way to allow all outputs to be utilized from the track input selection? maybe by summing them all together?
soundmind
Unread post by soundmind » 04 Mar 2011, 02:26
Actually, I just noticed the "mixer" modules within the "big mixer" patch in the library. This makes my request possible at patch level. Please disregard the above post.
soundmind
Unread post by soundmind » 04 Mar 2011, 04:04
actually I was wrong. this module also only outputs the first stereo pair of the track as well. I suppose I could just build this scheme using busses. thanks anyway.
Unread post by senso » 04 Mar 2011, 22:28
More generally, we have to retain the idea to have an input as a mix on several audio sources.
I know how to implement it but it's a long way...
Users browsing this forum: No registered users and 56 guests
