Lost between time & logic
inspired by a reactor patch, here what i try without success :
8 midi notes ( 36 to 43 here ) recall 8 presets ,
you play a note so you recall a preset , you made some changes if you want ..
when you play an other note, the patch save the first preset and then pass to the second one and so..
it's a kind of automatic preset manager
if some logic guru can help..
download
download
i've better result using data delay ( set to bloc size and bloc size x2 ) but it's far for be perfect..
last version :
download
download
Do you really need the num outlet nay-seven?
If no, try something like this perhaps:
Seb.Dub
well done ethnix,
and yes you're right , don't need the num inlet...:rolleyes:
thanks , really simpler !
it seems to be very fine but where do you wire it
good evening
good evening
Friedrich Nietzsche
Friedrich Nietzsche
it's a work in progress wao..
here a basic example :
download
you use midi note 36 to 43 to recall preset,
you can make some changes in each presets they'll be saved automatically...
download
hello nay i'm sorry but i understand nothing i'm not able to create anything in Usine
cause i don't understand 90% of the modules in usine i don't understand their functioning
i'm not able to use them i even don't know how to recall a preset without press on its number
i have not installed the last version i don't know if i must install all the additonals packs
Usine forum is the first thing i look when i start the computer because its the place where i learn a lot of
things of new technologies and for the ambiance there is in it but now i'm completely lost
excuse me once again
and thanks for your answer
i needed to tell what i felt
Friedrich Nietzsche
Friedrich Nietzsche
Users browsing this forum: Bing [Bot] and 28 guests
