Important update Usine 5.50.45 poly
Announcements
Unread post by senso » 28 Feb 2011, 15:18
[large]Usine / Easine 5.50.45[/large]
Important update, especially if you use the sequencer or midi-learns.
notes the structure of midi-learns has changed and all of them will be lost.
The good news is that, the new implementation is more efficient and stable.
improvements
- [sampler] the value of the pitch in sampler/grain sampler modules is now unlimited
- [dashboard Module] "Reset all Midi devices" inlet created
- [setup] "Reset all Midi devices" button added, in Midi in and Midi out panels
- [module] Open Dialog (to get a file name) created.
- [module] new ArcTan math module
- [library] new version of Freez
- [library] new version of Clock Beat
- [library] new Pitch Delay patch
- [library] new Sampler with Speed Button patch
- [Midi to Usine] num virtual inlet created.
fixed bugs
- [usine] sometime midi learn are lost on undo/redo in sub patches
- [vst] various buses issues in the VST version
- [sequencer] chaotic marker selection...
caco
Unread post by caco » 28 Feb 2011, 15:31
You are fast Senso, I only requested the new Open Dialog module a couple of days ago :)
Unread post by senso » 28 Feb 2011, 15:32
in fact this module was already implemented but hidden.:)
moody33
Unread post by moody33 » 28 Feb 2011, 17:01
Thanks to take care about our request Mr senso !
The beat clock modules seems to be a lot more solid ! (just testing by sending midi clock in usine, and it seems to be very stable).
You said "num virtual inlet created", but it was already implement , no? I've already plug a combo box in it in the last version.
However, it could be useful ( really useful in my case) to have more than 8 num virtual input, or more than 8 channels little switches in the upper mixer.
I was thinking to ask an Open Dialog box last week. Very nice module ! Thanks you.
Floego
Unread post by Floego » 28 Feb 2011, 17:26
Thanks for the reset midi function!:)
Unread post by senso » 28 Feb 2011, 19:14
the reset midi device is accessible within the Dashboard module.
So you can create button with a key learn for a fast reset.
senso+++
gurulogic
Unread post by gurulogic » 28 Feb 2011, 22:20
Thanks, this update has some nice improvements!
Unread post by grego mondo » 01 Mar 2011, 13:05
Thanks !
Midi learn re-done and here we go !
soundmind
Unread post by soundmind » 02 Mar 2011, 00:52
well done sir and thank you.
Users browsing this forum: Bing [Bot] and 6 guests
