Setting preset name with IML
gthibert
Unread post by gthibert » 26 Feb 2011, 20:28
Hi all,
I'm trying to set the name of a preset in preset manager using internal messages, but I can't get it to work.
I use SET_STRING_VALUE, but I can't set a value on terminals "0, 1, 2..." .
It actualy works if I set the value to a text field and link the text field to the preset terminal, but I wonder if it's possible to set it directly.
Guillaume
Guillaume Thibert
www.cemproduction.com
ethnix73
Unread post by ethnix73 » 26 Feb 2011, 20:40
It should work. I've just tested it and it's ok....
If the name of your preset manager is "pm", the message will be for example:
SET_STRING_VALUE pm 4 "yo!"
Seb.Dub
gthibert
Unread post by gthibert » 26 Feb 2011, 20:59
I'm trying thru a script, and it does'nt work.
SendInternalMsg('SET_STRING_VALUE', 'pm', '4', 'yo!');
Guillaume Thibert
Unread post by 23fx23 » 28 Feb 2011, 20:22
hi gthibert.
strange ive tested and it works here, did you made something to trig the code? set the patch as active patch? module is same renamed to PM?
here with a button i can rename correctly when clic on it, look like this:
Code: Select all
// parameters declaration
var go: Tparameter;
procedure init;
begin
go:= CreateParam('go',PtButton); SetisOutput(go,false);
end;
begin
 if ((n=go) and (getvalue(go)=1)) then begin
   SendInternalMsg('SET_TARGET_PATCH','SENDER_PATCH');
   SendInternalMsg('SET_STRING_VALUE', 'PM', '4', 'yo!');
 end;
end;
gthibert
Unread post by gthibert » 28 Feb 2011, 23:52
It works,
The line SendInternalMsg('SET_TARGET_PATCH','SENDER_PATCH'); was missing in my code.
Guillaume Thibert
Users browsing this forum: No registered users and 51 guests
