smaller bloc size
soundmind
Unread post by soundmind » 26 Feb 2011, 05:10
would it be possible to add a 16 and 8 size bloc to the global setup? I am generating some really smooth pitch jitter with the grain sampler at a 32 size bloc using some randomization to modulate the samplers pitch input and I would be willing to use higher cpu to get even smoother results because the smaller the bloc size, the less choppy and more smooth is the result. any chance of this happening? thanks.
Unread post by senso » 26 Feb 2011, 10:15
no pb, but remember, it will kill your CPU ...
next release
soundmind
Unread post by soundmind » 26 Feb 2011, 10:36
Yes I'm sure the CPU load will be high but not so much when using very simple patches and this will allow for ultra smooth modulations for the small bloc size enthusiasts. thanks a lot sir!
Users browsing this forum: No registered users and 29 guests
