3 new addons for your midi controllers
Unread post by nay-seven » 19 Feb 2011, 09:21
[center]Step Seq BCF2000[/center]
[center]A simple way to use your BCF2000 or BCR2000 as a midi sequencer, provide direct midi out ( if you use it as a sub-patch for example ) or by midi bus.[/center]
Check wiki here
[center]LPD8 Player[/center]
[center]A simple way to use your LPD8 as a multi samples player, control on pitch, several samples bank possible.( control by the program change of the lpd8)[/center]
Check wiki here
[center]Nano Kontrol Player lite[/center]
[center]A simple way to use your Nano Kontrol as a multi samples player provide control on pitch, volume, reverse function for each sample, several banks possible[/center]
Check wiki here
