Touchscreen theremin?
ethnix73
Unread post by ethnix73 » 18 Feb 2011, 00:53
I made a little experimentation tonight with my new touchscreen :D
Only bi-points but it's really fun.
So, with a really simple patch, i just try to emulate a kind of theremin:
A little video here
By adding a gain parameter controllable with the other hand, it might be possible to achieve something really fun to play
Seb.Dub
Unread post by woodslanding » 18 Feb 2011, 06:52
wow, I like the way this sounds.. Can you post your patch? I think you are right--with a little volume control you would have a fine theremin--actually closer to an Ondes Martenot!
Unread post by nay-seven » 18 Feb 2011, 09:04
great !
and the visual key is a good idea !
ethnix73
Unread post by ethnix73 » 18 Feb 2011, 10:10
I will try to improve a little this patch before uploading as an addon.
It's really simple. I use only a few midi create and event control modules:
When (mouse down), a midi note on is created. Then moving the finger just control pitch bend. And releasing the mouse, a midi note off is created reset the pitch bend.
I'm controlling a patch from my nord modular G2....
The visual keys are just a data step bitmap out linked to the bitmap in of a draw module.
Seb.Dub
multiphone
Unread post by multiphone » 18 Feb 2011, 10:31
Very nice idea !
HB
Lines / Points / Squares
http://www.hervebirolini.com/
caco
Unread post by caco » 18 Feb 2011, 11:35
Cool idea!
Unread post by grego mondo » 20 Feb 2011, 10:15
Great
Users browsing this forum: No registered users and 790 guests
