A vsti version of Usine so it could work under other sequencers...
It's a good suggestion, but an hard job.
Don't forget that Usine is designed to be a powerfull host in 'live' context.
Probably not enough for you!!!
Wait for the next version...
Vincent
Yes. Don't forget, we need it for live perf.
Make tracks is OK, you can find many tools.
Playing live... no soft does that correctly, except Usine. Nothing else exists. It is made for that and this is the reason why we are using it.
Live conditions are very hot and I think that Usine should continue to be developed for that special purpose as it is actually now.
(example: just stop for a while when overloaded, does not go OFF, things like that)
hcv242 had a good idea indeed, but it's not time now I think for such an improvement.
Users browsing this forum: No registered users and 51 guests
