delay adjusted to sample lenght
tanabarbier
Unread post by tanabarbier » 06 Feb 2011, 09:17
Hi everybody
I'm trying to adjust the delay line time to the sample lenght, and to keep it adjusted when I change the pitch. I've been looking for the formula, but I don't find it anywhere...
Anyone can help me ?
Thanks a lot !
ethnix73
Unread post by ethnix73 » 06 Feb 2011, 11:44
A few times ago, i made a littlle add-on to convert lenght and pitch to tempo.
You can find it in the add-on section synchro,time named Pitch shifting , lenght and BPM conversion
Use it with the tempo to delay Usine subpatch you will find in Modules/Synchro&Time...
It should do the trick.
Seb.Dub
