Something wierd is hapening in a patch I'm builting :
It contains sample players going through an fx section and then loopers.
The thing is that when I use the "key learn" (or "MIDI learn", too) fonction on the preset manager that loads differents sounds with each sample player, first it works perfectly, but when I save the patch and reload it (or re open the workspace later) the key (or MIDI) assignations in the remote are duplicated on the preset manager that is inside the fx subpatch.
It's quite clear that I don't really understand the preset manager, but am I missing something with the remote ?
Thanks in advance for your help !
Problem with preset manager and remote
tanabarbier
gone to check, maybe something with the target of the preset manager
tanabarbier
These preset key learn problems seem to have spreaded into some others patches.
Now in every patch that as more than one preset manager all the remote assignations are copied from the first to all the others (first from up to down and left to right).
This is quite unpracticle... Anybody as an idea of what should I check ?
thanks !
thanks !
sorry I forgot to tell you
senso solve it , next release (soon )
tanabarbier
Aaaah thanks a lot, waiting for it eagerly !
Users browsing this forum: No registered users and 28 guests
