Each time I start usine, I get a UAC request for the software. This should normally only happen during installation (or when doing some files association routines) but I get this every time I run Usine.
Does anyone have a clue on how to get rid of this ?
problems with UAC in Win7x64
my first answer would be : do you really need UAC..?
then, generally,as you said, it's happen only one time ( Usine don't have installation,, it's a portable software )
Try this: right click the .exe and click properties and then the "compatibility" tab, then the button that says "change settings for all users" at the bottom, and then click "run this program as an administrator" under Privelege Level.
Document02
- New member
@rungate: didn"t work. Thanks anyways.
Actually I found a workaround, but am not sure it is good practice: directly launch UsineFileUsineMain.exe .
i think you can safely directly run usineMain.exe. i do this as well
Users browsing this forum: No registered users and 365 guests
