Ok, so we think to clean the library of Usine and your help / opinion interests us
So if you have ideas for simple patch that could be helpful in everyday life, and if you don't really like patching .. do not hesitate to propose your idea here
Here is already some patch I 'll work on :
_A simple recorder controllable by a midi footswitch or other (inspired by the idea of an audiofanzine forum user)
_Same for a midi recorder
_A multi sample player designed for the Nano Korg Kontrol
_The same idea for a akai LPD8
_A simple sequencer based on the BCR2000 (an old project that I'll rework)
_A generic and configurable patch based on the FCB1010 pedal
Poll: what kind of patch you need in the library
Hey, I don't know if it's possible yet, but I'll toss out the automatic sampler again.....
Recorder that is triggered by input, analyzes the pitch and volume, and automatically names the sample based on these values.
Still needs saveAs text input for sampler, I think. But maybe there is a way around this?
-e
-e
a little bit off topic (it's more a suggestion). Actually there is no way to set the 'save as' text. I don't know how to implement it, but I'll think about.Still needs saveAs text input for sampler, I think. But maybe there is a way around this?
i thought about a workaround tracking random names usine can give and use a script to rename those files on hd, do you think that could be possible to rename files via script? gonna try to give a shot this we...
Users browsing this forum: Bing [Bot] and 27 guests
