Ohm64 and Usine
Unread post by nay-seven » 31 Dec 2010, 18:07
i recreate here a question about he ohm64 from the user ZOUKOUPOMME, better to have a separate thead ..
ZOUKOUPOMME :
Hi
I just had " USINE 5.25" .I have recently a controleur " ohm64 " .I would want that the leds of this last one remains lit(switched on) when I assign them has a button " play "or" lapel(backhand,lapels) " for exemply. I have to try to follow advise(recommend) them " to pilot external devices " of your wiki doku, but without resultat.
Have-you a solution has my probleme?
I thank you for it beforehand.
Je viens d'aquerrir"usine 5.25".Je possede depuis peu un controleur"ohm64".Je voudrais que les leds de ce dernier restent allumée quand je les assignent a un bouton "play" ou "revers"par exemple.J'ai essayer de suivre les conseilles dans"piloter des appareils externes"de votre wiki doku,mais sans resultat.
Auriez- vous une solution a mon probleme?
Je vous en remercie d'avance.
nay-seven :
hello and welcome zoukoupomme !
first , maybe better to open a new thread for this, this way could be useful and easiest to find for others omh64 users..?
now , i need some precision to help you :
_first, buttons on the ohm64 are in toggle mode? , i mean without Usine you can have on/off position yet..?
_then in Usine you can use midi learn on your switch , then right click and choose remote mode toggle
_now if you want remote this usine switch to your ohm64 , right click on this switch /find in remote panel and activate the remote button
_you must have select your omh64 as midi out in your global setup/midi out and activate also the remote function here..
tell me..
ZOUKOUPOMME
Hello nay-seven!Thanks!
- for the buttons of "ohm64" I have the choice between: "note" or " control " but not toogle
- for "usine" I chose " toogle mode"
- I have make reglages in " global setup " .
But her(it) that does not work.sad
Unread post by nay-seven » 31 Dec 2010, 18:10
ok, so i've check the Ohm64 forum and found that you have to deal with note on/off message to have toggle mode for you controller :
check this discussion :
http://blog.lividinstruments.com/forum/ ... hp?id=1363
Unread post by nay-seven » 31 Dec 2010, 18:34
mm, reading all the livid forum post , seem that must work also in CC mode,
what you can do is using the console ( black window right the dashboard in Usine):
first activate the trace in button in your global setup/midi in/ and check the number of cc you receive when you press your ohm64
then deactivate it, and now activate the midi out trace function , and check that when you use the Usine switch you see th e same cc number in the console..
ZOUKOUPOMME
Unread post by ZOUKOUPOMME » 31 Dec 2010, 18:37
Thank you for the news post nay-seven!!
I am going to make a tour on the livid blog.
ZOUKOUPOMME
Unread post by ZOUKOUPOMME » 31 Dec 2010, 18:50
Thank you for your help nay-seven !
I am going to look at all this tomorrow has rested head...
Cross good parties!!! ;)
ZOUKOUPOMME
Unread post by ZOUKOUPOMME » 01 Jan 2011, 18:58
Hi nay-seven! Happy new year!
I put the keys(touches) of "ohm64" in mode cc.
On the console we can see for example:
When I supports:
[100] IN:0000C9AA:176-63-127-CC [ chan=1 ]
When I lache:
[101] IN:0000CCD8:176-63-00-CC [ chan=1 ]
The led does not remain lit(switched on) When I declenche a sample.
Please help me:/ !
Unread post by nay-seven » 01 Jan 2011, 19:33
ok, and now if you deactivate the trace in, activate the trace out and click on the switch in Usine, have you the same message..?/number
ZOUKOUPOMME
Unread post by ZOUKOUPOMME » 01 Jan 2011, 20:54
the switch ?in the patch?
Unread post by nay-seven » 01 Jan 2011, 21:26
yes..the one you use for your midi learn..?
ZOUKOUPOMME
Unread post by ZOUKOUPOMME » 01 Jan 2011, 21:35
I does not include your question? :(
ZOUKOUPOMME
Unread post by ZOUKOUPOMME » 01 Jan 2011, 21:36
desolate
Unread post by nay-seven » 01 Jan 2011, 21:58
mm, you use the ohm64 switch to make a midi learn on a Usine switch , right..?
and you have use the remote function..? so when you use this switch in Usine he also send midi message..?
so i ask you to trace this message in the console
ZOUKOUPOMME
Unread post by ZOUKOUPOMME » 01 Jan 2011, 22:22
I have a little difficulty has to understand.
what I have make for the moment:
- I right click on play
- I click on " midi learn " (I chosen " remote toggle mode")
- I supports on the button of "ohm64"
you don't speak french!!?!! ;)
Unread post by nay-seven » 01 Jan 2011, 22:28
yes, i speak french but here on this forum we only speak English..
if you prefer speak French you can use the audiofanzine forum : http://fr.audiofanzine.com/sequenceur-d ... -5/forums/
btw , I've found an other topic ( in French ) about your controller : maybe can help us :
http://www.fruityclub.net/materiels-aud ... eur-ohm64/
ZOUKOUPOMME
Unread post by ZOUKOUPOMME » 01 Jan 2011, 22:49
En effet j'utilise fl studio pour la compo musical et j'en suis satisfait de se cote là.(Pourquoi me renvoyer sur un sujet que j'ai ouvert sur fruity club???) Pour faire de l'impro en electro il ma sembler judicieux de choisir usine pro...je prefere etre sur votre forum quitte a m'arracher les cheveux pour la traduction de notre conversation,car il me semble a premiere vu que vous etes la personne la plus apte a me repondre ?
Unread post by nay-seven » 01 Jan 2011, 23:06
je suis aussi sur audiofanzine..mais ici c'est le forum international , donc on parle uniquement anglais..stp ( et je ne pouvais pas savoir que c'était vous sur l'autre forum...? )
I'm also ready to answer you on the French forum...
ZOUKOUPOMME
Unread post by ZOUKOUPOMME » 01 Jan 2011, 23:21
Ba oui c'etais moi sur fruity club!ainsi que sur le sujet"http://blog.lividinstruments.com/forum/ … hp?id=1363" !!! lol
I would formulate a question tomorrow on audiofanzine. Thank you for your support.
Users browsing this forum: No registered users and 134 guests
