I'm trying out Usine, but there are no modules or anything else showing up in the Browser. I've downloaded and installed it twice, as well as tried to configure the directories manually.
Does the free version not include any modules?
Running Windows 7 pro 64-bit.
Usine Free: No Modules in Browser
Hello and welcome
have you try to double click on the triangle in the browser..?
if yes, can you check the files are in your dir : files/modules...
Users browsing this forum: Google [Bot] and 507 guests
