playing with fft vocoder add-on
Hi
I'm interested by phase vocoder add on but i don't know how use that.
I'd like for exemple cut my signal in 6 band of frequencies (i play the guitar and i 'd like to get the signal of each string separatly).
Is it possible ?
Is it possible to make a filter with a very hard Q ?
is it possible to make a 31 band freq eq ?
is it possible to make a vocoder witch modulate the frequency of a instrument by the amplitude of another one ?
How could we do that ?
thank you
jof
Is it possible ?
thank you
jof
maybe you can test with caco's filters
but about separate each strings...what's happen when you play a bass string on the low part of the neck ..?
i think it will be interpretated as another string
headphoner
don't forget the latency with fft modules and phasevocoder modules
yes i know.
where can i find caco's filter ?
headphoner
headphoner
maybe this solutionis it possible to make a vocoder witch modulate the frequency of a instrument by the amplitude of another one ?
http://sensomusic.com/forums/uploads.ph ... ossFFT.pat
sorry but it doesn't sound like a vocoder...
headphoner
i said maybe
build your own
build your own
or get the free TAL vocorder vst.
Not the best vocorder ever, but a lot of fun.
-e
-e
