Midi usine Problem
yooha22
Unread post by yooha22 » 18 Nov 2010, 16:53
Hi guys
Probably all of u tried using usine as a midi controller , i was makin some templates and setups then i realised one parameter can only be mapped to one midi message ,
Example
in usine u make a fader to control a volume fader as a midi controller in fl studio ,,,, then the problem comes when u want to use an actual controller (hardware like bcr2000) to control usine ,,, the same fader ,,, then it would logicly be bcr2000---->usine FAder -----> fl studio
but when u come to map both to the fader , i mean the fader in fl studio and a rotary in bcr2000 , u can only do one , or i dont know maybe some other problem :(:(
does anyone now how to fix this
Unread post by nay-seven » 18 Nov 2010, 17:11
hello and welcome yooha22
here a little patch you can do :
the vertical fader has a midi learn to be controlled by your bcr,
I've set his max to 127
the midi create module is set to control change
and his code 1 is the number of the controller you want send :
yooha22
Unread post by yooha22 » 18 Nov 2010, 17:25
That is one Fast support , Thx , ill check it out thank you
Unread post by senso » 18 Nov 2010, 17:29
You'll see, the Usine community is very active!
Thanks for their great job to help new users.
Also, do you have noticed that in
Browser / Midi / Midi Interface Objects you have many ready made objects which are exactly what you need.
yooha22
Unread post by yooha22 » 18 Nov 2010, 21:07
Awesome ,
Ill check that soon thx ....
I found another way , should i say it here ?
Cheers to Senso
Unread post by nay-seven » 18 Nov 2010, 21:20
no problems, you'll see that there's always several ways with Usine
Users browsing this forum: No registered users and 454 guests
